Need help with sub panel location
Old 09-26-17, 05:28 PM
I've been racking my brain on this. Building a 500 sq/ft addition. Ran 6/3 wire to the addition side of the house with about 15ft of slack. Trying to decide on putting the sub panel in the basement near the crawl space opening. https://prnt.sc/gq4m3q running the wires up and in from the floor.
Or....
Put it in the 2x6 wall in the spare room in the addition?
Old 09-27-17, 07:59 AM
I
Received 43 Votes on 41 Posts
Yeah it looks like the sub can probably go there, but that shelving unit has to move. Panel clearance is 30" wide in front of the panel (the panel does not need to be centered in the 30"), and 36" out from the face of the panel. The highest breaker must be less than 6'-7" from the floor. Basically you need to be able to slide a refrigerator box up to the panel without hitting an obstruction. Storage of any kind is not permitted in front of a panel.
Old 09-27-17, 10:17 AM
CasualJoe's Avatar
Received 83 Votes on 73 Posts
I'd put the subpanel in the basement.
Old 09-27-17, 02:18 PM
Okay new location possibility...
https://imgur.com/a/XLLCW
The resolution of the attached image is horrendous. That's why I'm linking the imgur link.
Old 09-27-17, 03:43 PM
Tolyn Ironhand's Avatar
Received 200 Votes on 178 Posts
24" is not enough space in front of a panel. 30" is minimum. The laundry tub is fine, the drain is not.
Old 09-27-17, 04:31 PM
Hrmm. I was afraid so. I guess the original location it is then. Unless I move back into the addition itself.
