DryConns for outdoor thermostat wire connections
Old 09-28-17, 11:36 AM
Received 25 Votes on 17 Posts
I wasn't sure if this was better under the wiring section, or the thermostat section. Feel free to move.
I am replacing an outdoor temperature sensor for my thermostat. There is a run of 18AWG CL2 thermostat wire going from outdoors to the T-stat, and I need to connect it to the sensor. The sensor has 18AWG lead wires. Would I be OK just using some DryConns to make the connection, or should I further enclose it somehow?
The DryConns say: "UL 486D listed as a sealed wire connector system. For use in damp, wet, raintight, direct bury, and submersible locations." Reading that, I want to say it's fine by itself, but I'm double checking. Thanks!
Old 09-28-17, 01:15 PM
I
Received 43 Votes on 41 Posts
Yeah those are OK, crimps or bugs would be OK, just plain wirenuts would be OK if you orient them like hats so the water won't collect.
