downstairs doorbell does not ring
Old 10-01-17, 08:55 AM
E
The ringer for the upstairs works just fine but the downstairs no longer rings. They both run off of the front door button.
Old 10-01-17, 10:07 AM
Received 1,019 Votes on 946 Posts
Welcome to the forums.
You have two ringers off the same button and transformer.
One ringer is working so that would suggest starting right at the second ringer.
What is at the second location ?
If you don't what it's called.... post a picture. http://www.doityourself.com/forum/el...-pictures.html
Old 10-01-17, 12:00 PM
E
Thank you for your help. I know little about electricity but do have a multimeter and know how to use it.
Hmm trying to upload a photo and it says upload failed.
Old 10-01-17, 12:39 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Phone pictures are often way to large. Try reducing it to 800px x 800px. http://www.doityourself.com/forum/li...rt-images.html
Old 10-01-17, 12:54 PM
E
Yup. A little cropping goes a long way.
Old 10-01-17, 01:14 PM
If that is the non working doorbell...... try moving the red wire from front to rear.
If that works.... the front door coil is defective or the right plunger is stuck.
If that doesn't work... you'll need to check the wiring at the working doorbell.
Make sure you use two people for testing. Someone needs to be at the chime unit. Many times when using two chime units... the transformer size needs to be upgraded. This becomes more of a noticeable problem as the units get older.
