Drill bit to go through floors?
Old 10-09-17, 07:54 PM
Q
Received 1 Upvote on 1 Post
I need to go through my floor to get a hole open in the crawl space below my house and then pull some wire.
difficult to say what the exact thickness is - any recommendations?
I've also seen these flexible drill bits 6' long - what and when are those used?
Old 10-09-17, 10:26 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
Whats the floor material and how big will the hole be? They make regular wood spade bits with 16" shanks (search for Irwin long shank spade bits) or you can buy an extension for regular spade bits anywhere, as long as the hole is big enough to fit the socket end of the extension through.
Old 10-10-17, 01:04 AM
Q
Wood floor maybe plywood underneath then sub flooring then framing/joists.
difficult to know if I'm directly above a joist or not?
Are the 6' long flexible drill bits any good? Hardware store only seems to have those.
Old 10-10-17, 03:52 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
You do not want to drill through a joist. Drill a small pilot hole and see how thick it is. Any 6 inch drill bit should work. Floor should be less than 2 to 2 1/2 inches thick. Measure from outside wall to Joist and take that upstairs and repeat.
Old 10-10-17, 04:39 AM
P
Received 2,185 Upvotes on 1,955 Posts
Almost any drill can drill through a wood subfloor. General purpose twist drills are what I use most often as one wire usually needs a 1/4 - 1/2" hole. Spade bits also work but they tend to be larger than needed for unless you are running a large wire or several wires.
The long bit you mentioned is used for fishing wires through walls. You would cut an opening in your wall the size of an outlet box. Then insert the drill through the hole. And using the metal handle that comes with the drill you bend the shaft inside the wall so you can drill down through the base plate. This allows you to run wires between floors without them being visible.
Old 10-10-17, 06:45 PM
Q
Is a right angled drill worth getting to drill holes in studs in tight places or can I get a short flex shank and just use a normal drill?
Old 10-10-17, 07:05 PM
pcboss's Avatar
Received 196 Upvotes on 172 Posts
Drill from the bottom up.you can come in the stud cavity.
Old 10-11-17, 10:09 PM
Q
If there are no reference points how do you get the exact point to drill up through?
Old 10-12-17, 12:35 AM
ray2047's Avatar
Next to the wall where you want the cable drill a 1//8 inch hole through the floor and insert a stiff wire. Then look for the wire from below.
Old 10-14-17, 11:07 PM
Q
Couldn't floor be 2" base plate + floor + subfloor + air gap?
Old 10-14-17, 11:29 PM
ray2047's Avatar
ĺ" floor + ĺ" subfloor =1Ĺ". A standard length nay be enough or get a longer bit or use a length of straight coat hanger wire. What is a base plate? What airgap? Feel like we are not talking about the same thing. Of course here there often isn't even a subfloor.
Old 10-15-17, 08:19 AM
Q
Joist headers or sill plates...
Old 10-15-17, 02:44 PM
ray2047's Avatar
They're under the wall. I said to drill through the floor next to the wall.
