Transistor Switch recommendations?
Old 10-30-17, 10:51 AM
B
Received 2 Votes on 2 Posts
Question Transistor Switch recommendations?
Decades ago I used to know all I needed to build an electronic gadget.
Now I have no clue what parts even exist.
However, I need to set up something that requires a switch. Input 5 V, max 2 mA. Output 14 V, more amps is better, but not important, I can use a relay to feed the load 3 A. Is there a transistor IC that can do it for me?
Old 10-30-17, 10:59 AM
Received 2,955 Votes on 2,666 Posts
I would highly recommend the ELK 924 relay module to do what you need.
ELK-924_Instructions
Old 10-30-17, 11:19 AM
B
Thanks! Digging into it ...
Edit: Perfect!
Old 10-31-17, 06:41 AM
G
Received 1 Vote on 1 Post
What you describe is a Solid State Relay. No mechanical contacts.
Here's a $12 example from Amazon.
Old 10-31-17, 06:54 AM
B
Received 42 Votes on 38 Posts
I feel your pain Bitjam. We come from an age of emitter, base, and collector and like you, I no longer know what is available. The pros here are good (and a bit younger) so I always know where I can ask. Well at least some are younger (Furd).
Bud
Old 10-31-17, 08:18 AM
F
Received 36 Votes on 28 Posts
Yes, I'm younger than some but is 67 years really considered young?
Oh, like Guy I also thought of a solid state switch.
Old 10-31-17, 04:08 PM
I'm not a big fan of those solid state relays switching DC.
In this members application I'm sticking with the ELK board.
