leroy somer air compressor wiring
Old 10-30-17, 01:41 PM
K
I have recently bought this air compressor and there are wires attached to it but I want to make it 110v instead of 220. It only has the 3 orange wires coming from the motor. What wire does what?
Old 10-30-17, 02:56 PM
P
Received 210 Votes on 178 Posts
My eyes must be going bad, but that motor data plate says 575/600V. From whom did you buy this compressor? OH.. it's 3 phase. I think you're out of luck with it being 600V 3PH, but maybe someone will reply with a solution. You may need to buy a new motor.
Old 10-30-17, 03:27 PM
Received 2,953 Votes on 2,664 Posts
Welcome to the forums.
I enhanced the ID plate. It is indeed a 3 phase 600v motor.
Not going to work on lower voltage.
Old 10-30-17, 03:48 PM
K
so what you are saying is it can only be ran on 220?
Old 10-30-17, 04:08 PM
No.... it can only be run on 600 volts.
That is a special industrial motor.
Old 10-30-17, 04:45 PM
P
I doubt you have 3 phase power so that is another issue.
