Telemecanique LC1D09 contactor wiring
Old 11-04-17, 08:50 AM
D
I just received a replacement card that runs the opposite of the previous card. Now when the circuit is close it is not running and when the circuit is open it runs. Right now the two wires running from the switch Telemecanique LC1D09 to the circuit board are coming from 2T1 and 6T3. What are the steps I need to flip it to the opposite state? Thank you for any help in advance.
Last edited by PJmax; 11-04-17 at 04:45 PM. Reason: added picture of contactor and added contactor to title
Old 11-04-17, 09:06 AM
P
Received 1,571 Votes on 1,412 Posts
Why don't you start by telling us what you are working on.
Old 11-04-17, 04:42 PM
Received 2,969 Votes on 2,679 Posts
Welcome to the forums.
I added a labeled diagram of your three phase magnetic contactor.
L1, L2, L3 are power input.
T1, T2, T3 are switched power out.
L1 closes to T1, L2 closes to T2 and L3 closes to T3 when activated. This is the way any standard magnetic type motor contactor works. There is no reversing the output. There are ONLY three normally open contacts. There are no normally closed contacts.
The numbers and letters in the white section are switch contacts for remote start/stop switching, They are not to be used to switch a load.
