Am I looking for a unicorn?
Old 11-07-17, 04:27 PM
Received 3 Votes on 3 Posts
My 11000w generator came up missing out of our shed. Fortunately, I had an older 6500w genny in our garage. Until I can replace the larger genny, I need to be able to connect the smaller genny to our 50amp inlet circuit for emergency backup power to our house.
The power inlet box has a 50amp C6365 connector. While the smaller genny has a 30amp twist lock connector. Is there an adapter where I can use the 50amp cord from the house to an adapter that plugs into the smaller genny????
I've been looking online, but either that adapter doesn't exist or I'm as blind as a bat. Thanks!
Old 11-07-17, 05:25 PM
Tolyn Ironhand's Avatar
Received 597 Votes on 512 Posts
Is the smaller generator 30 amp twist lock also a 125/250 volt, or just 125 volt?
You might have to make up your own adapter.
Old 11-07-17, 05:58 PM
It's 125/250 volt 30amp. Sorry for leaving that out.
Old 11-07-17, 06:21 PM
Received 2,973 Votes on 2,682 Posts
Old 11-08-17, 03:06 AM
Thank you very much!!!!!!!!!!!!!!!!!!!!
