Fishing new wire through walls - advice
Old 11-08-17, 05:03 AM
D
I'm upgrading my security camera system, which means I'll be trying to fish new BNC cables through the walls, using the old mini DIN cables as bait.
How can I connect the old cable ends to the new ones securely, so I don't lose the connection in a wall? Anyone have advice on this? Thanks in advance!!
Old 11-08-17, 05:10 AM
P
Received 1,561 Votes on 1,404 Posts
Strip back the insulation and bend/tie the metal conductors together then cover with electrical tape so it's smooth with nothing to snag.
Old 11-08-17, 05:13 AM
D
So I'd cut off one connector-end of each cable, and then re-connect the one I'm still using after the operation? That makes sense! And thanks so much for the quick reply! :-)
Old 11-08-17, 05:15 AM
Geochurchi's Avatar
Received 154 Votes on 140 Posts
Hi, I assume you mean Coax cable for BNC cable,are the connectors already installed on those cables? If not ,I would cut off any old connectors and tape the cables together forming one cable,over lapping about a foot.
Geo
