Three way switches for kitchen lights
Hi-
We just moved into our home. Our kitchen has two switches for the kitchen lights. The left side of the room switch side has a dimmer and the right side is just toggle.
The problem I am having is that if the left switch turns off the lights then the right cannot turn them on and vice-versa. I have never seen a setup like this.
Please tell me there is a way to fix this. I should be able to turn the lights on from either switch regardless of which one turned them off correct?
TY!
TY!
People get VERY confused with three way circuits. I have not found many dimmer/3way switch combinations that work correctly. That leaves you two choices.
1) remove the dimmer and install a regular three way switch.
2) purchase a three way dimmer and it's companion switch.
