Is it ok to have too little load on circuit?
Received 0 Votes
I have a wire that was already run to my basement bathroom that is a 12-2 red wire(black and red conductor). I was going to install a heater and according to Stelpro(heater manufacturer) it takes 10w of heating per square foot of the room. So for my small bathroom, a 500w heater would be enough. Since the already run wire is a 12 gauge, I thought the breaker amperage had to match the wire size so I was thinking of installing a double pole 20amp breaker, but the heater will only draw 2.08amps(500watts/240Volts). Is it bad to have too little of a load on a circuit? Do I have too available current in case the device decides to malfunction, the breaker won' trip?
The minimum amperage branch circuit is 15 amps.
The appliance, etc. will draw just the amperes it wants. It is impossible to prevent all possible fire hazards that a 3 amp appliance could malfunction into if it had 20 amps at its disposal but not be a hazard if there could exist a 5 amp circuit to plug into. However all appliances, lights, etc. using less than 15 amps and with proper (usually Underwriters Labs) approval are designed to be plugged into a 20 amp circuit and it is not against code.
If you are sure that other things will not be plugged into the circuit at the same time you can installe a smaller rated breaker for example 15 amps on what was a 20 amp circuit.
Since that is a 240v circuit.... there is little chance of something getting plugged into it. Use a 2P15A breaker to protect the circuit.
