Making it easier to pull cable?
Old 11-26-17, 05:47 PM
Q
Received 1 Upvote on 1 Post
I have to pull around 80' of cable from a 3rd floor apartment to a basement to connect to a new water heater.
is there anyway to make this easier as there are a few 90 degree bends along the way...
I was going to put a spool at the top and just start pulling from the floor below before going across a suspended roof and then straight down. I fear I'm going to be running up and down stairs all afternoon just feeding it through when it gets stuck.
Old 11-26-17, 06:23 PM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
With that many bends you are going to be doing segmented pulls.
Old 11-26-17, 06:49 PM
Tolyn Ironhand's Avatar
Received 672 Upvotes on 570 Posts
Get a friend to help.
Old 11-26-17, 11:01 PM
Q
Best to measure the full 80' first and unravel it then or leave it on the spool and keep running it in segments. Probably 3 X 90 degree bends and then some joists in the crawl space after that.
Old 11-27-17, 06:01 AM
Q
Is it best to measure the full 80' first and unravel it then or leave it on the spool and keep running it in segments? Probably 3 X 90 degree bends and then some joists in the crawl space after that.
Old 11-27-17, 06:45 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
What size conductors are you pulling?
Geo
Old 11-27-17, 07:16 AM
D
The waste stack is probably a straight run. Is it against code to run it along side that?
Old 11-27-17, 07:40 AM
I
Received 45 Upvotes on 43 Posts
In older houses the waste stack is usually a good place to get a chase from bottom to top of the house. Newer houses it doesn't work because the penetrations between floors are sealed up better.
Old 11-27-17, 01:53 PM
Q
There are some cupboards also used for pex pipe. I was thinking of using the same cupboards as it's a sort of cavity between floors. 10/2 cable.
it's not the where so much as the method of pulling segments.
Old 11-27-17, 03:13 PM
D
As Tolyn suggested, you need a helper. Don't try to do it alone.
Old 11-27-17, 04:23 PM
L
Received 177 Upvotes on 152 Posts
If you have to do it by yourself, it will help to build some jig to straighten cable entering the conduit. You can probably build one using 2x4 and suspend the cable on 2x4.
Using stranded THHN wires will help to. Pulling solid 10-2 NM-b in conduit with many bends will be very difficult.
If some part of the run is outside conduit, you can install junction box at the end of the conduit and change over to NM.
Old 11-28-17, 12:14 AM
Q
A junction box halfway might help?
Old 11-28-17, 05:17 AM
Q
I wasn't planning on using conduit at all... just fishing NM through the ceiling and floors. Any benefit to using conduit? Won't it be much harder to install?
Old 11-28-17, 05:24 AM
Geochurchi's Avatar
What is this suspended roof you are pullin across?
Old 11-28-17, 05:40 AM
Q
Suspended ceiling. Tiles can be lifted and moved.
Old 11-28-17, 01:38 PM
L
I thought you had a existing conduit because you mentioned 90 bends. If there is no conduit, yes it will be more work and there will be no benefit.
You will have to cut drywall in multiple location and pull cable in multiple steps. Making drywall cuts bigger will make pulling wire easier. Pull wire all the way at each 90 bends then feed it. Having a helper will make things much easier.
If you can and don't mind conduit along outside wall, it might be easier to install conduit at outside wall and pull cable in the conduit. This will make vertical runs much easier and possibly no need to cut drywall if you have suspended ceiling.
Hardest part here probably is that you will need long ladder and not afraid of the height.
