solution for outlet plates
I redid my family room and had to screw/tape 3/8" drywall over 1/2" drywall. It was the easiest solution instead of ripping the old 1/2 sheet rock down- The room looks good except that the outlets and switch cover screws don't reach (which I knew was going to be an issue going in)- I can get longer screws but it looks crappy- Is there any other solution for this?
There are box extensions. You just screw them onto the front of the existing boxes to space the front out to be flush with the wall. They are available in different thicknesses or you can stack a couple shorter ones to get what you need.
And the trick is you want to remove the receptacles, and mount them against your new drywall (using the box extenders others have pointed you to). The plates go on as normal.
You will want to turn off the circuit breaker for your receptacles though so you don't accidentally get zapped while moving them around.
Did you cut the holes in the sheetrock too large. There should be no visible signs of longer screw use. The box extenders are used to fill the gap between the box and the sheetrock. They also keep the device from getting pushed into the wall when used. If the hole is too large.... they aren't of much physical help.
