Replaced fluorescent light ...
Old 11-28-17, 03:40 PM
B
I replaced a fluorescent light that had a built-in power receptacle (that didn't work) with a recessed light. I did such a great job that the new light refuses to shut off at the switch. I wired the new fixture exactly as the old fixture but I'm wondering: Could the problem be that the old fixture was wired so that the receptacle would work even when the light was turned off? All help is greatly appreciated.
Old 11-28-17, 03:48 PM
D
It looks like you bypassed the switch by connecting the wires that you have marked "confused", to the hot lead.
Old 11-28-17, 04:01 PM
B
Yes, by process of elimination, I did. It was the only open lead left on the new fixture. How do I fix it?
Old 11-28-17, 04:50 PM
Received 4,056 Upvotes on 3,639 Posts
This is the correct wiring. You use switched hot and neutral.
Name:  Screen Shot 2017-11-28 at 5.44.00 PM.jpg
Old 11-28-17, 07:13 PM
B
You are a life saver! Thank you, so very much. I'll try this in the morning and let you know how it goes.
Many thanks, again!
Old 11-28-17, 07:18 PM
pcboss's Avatar
Received 202 Upvotes on 176 Posts
You connected to the constant hot in the box, not the switched hot.
