Converting hard wired range hood to plug in type
Received 0 Votes
I am replacing my current range hood. It is hard wired and the new one I want is a plug in type. Can I just take the wiring from the wall and hook up a plug in box. Would it need a dedicated line or can it be on with the lights or whatever else is on that circuit? I live in Texas.
If you are going with just a new range hood and not an over the range microwave, or something like that, the existing circuit should be fine. Depending on your wiring method, if it is non-metallic (Romex) or metallic (AC/MC/BX cable or FMC) you will just need to install a single gang remodel box and install a receptacle/plate.
Metallic box:
https://www.homedepot.com/p/2-1-2-in...1-NM/204609680
Non-metallic box:
https://www.homedepot.com/p/1-Gang-1...14RB/100404027
Metallic box:
Non-metallic box:
