2 Pole Switch Help
Received 0 Votes
2 Pole Switch Help
I am adding a bathroom exhaust fan to our bathroom. The light switch for the existing bathroom light is through the fixture power. I bought a double pole switch - will use one pole for the existing light and the other for the new fan. Am I wrong to think this will bring power to the fan pole if I leave the breakaway tab in place? When I wire the fan itself at the fan do I leave the white cable alone and wire everything else to the black?
Do you have a single two wire cable at the switch ?
Or.... do you have two cables at the switch box ?
Received 0 Votes
There are two wires coming in to switch box. They were hooked to a single pole switch. I bought a two pole switch. I wired the existing wire to one pole on the new switch. I then ran new 14/2 from the newly installed fan down to the second pole on the new switch. At the fan, I wired black to black, white to white and ground to ground. Checked my work, flipped switch for fan and nothing. The light on pole one did work on new switch.
The black wire is (should be) switched hot back to the light.
You have what is known as a switch loop. You do not have a neutral in the switch box. You cannot tap anything off of a switch loop.
This is what you have there.....
Received 0 Votes
Thanks for all the replies. I went back into the attic today and also looked at the wiring behind the existing light and see where the incoming power is. At this point it sounds like I run 14/3 to the new fan and then the 14/2 to the double pole switch? There is power going to an outlet also at the existing light which makes this a little less straightforward.
