Installing a New Outlet Box
Old 12-08-17, 06:13 PM
I want to hang a TV on a wall at about eye height.. The wall is a studded exterior wall that has access from above where I can get the wiring and coax down. I know to hang the TV mount to the studs and my question is what is the proper way to affix the boxes for the electricity and cable?
Thanks for the help.
Old 12-08-17, 06:25 PM
Tolyn Ironhand's Avatar
Received 73 Votes on 65 Posts
Use a remodel box which will mount to the drywall. For the cable I recommend a low voltage ring. The low voltage cable and power cannot be in the same box
Old 12-08-17, 06:27 PM
Received 511 Votes on 481 Posts
Use a combo electric and low voltage box. It mounts between the wall studs. The one in the link is from amazon. Depot has a similar type..... a little less money. They come as a complete kit with the receptacle. The electric is contained in its own junction box.
Pass/Seymour-TV1WTVSSWCC2-Recessed-Television-Installation-box
Old 12-08-17, 07:02 PM
Gunguy45's Avatar
Super Moderator
Received 2 Votes on 2 Posts
Pete...are those old work or new work mounting?
Old 12-08-17, 07:05 PM
OK, I'll check them both out, thank you.
Old 12-08-17, 07:31 PM
They are old work. You locate the two studs and cut a hole between them.
It has wings that hold it in place.
They are good to use when you are using a non articulating TV mount. That style mount keeps the TV close to the wall and little room to plug in. I can plug in the TV and an AC adapter.
This is the link for the other model. This one is less expensive. I put a piece of foam in the cable opening to keep the cold air out.
Commercial-Electric-Low-Voltage-Recessed-Media-Plate-with-Duplex-Receptacle
Old 12-08-17, 07:32 PM
pcboss's Avatar
Received 39 Votes on 34 Posts
Arlington makes a nice combination box for power and cable.
Aifittings.com
