Installing P & S vacancy sensing switch
Received 0 Votes
My friend installed the RW600BTCCCVR but we do not understand how to turn it "on". In other forums I see the area on the bottom of the switch is the "on" but it does not toggle or have somewhere to push. The light was on after installation, and it do go off.
RW600UTCCCV4 is one of the popular controls. Is that what you have ?
The button is that little indentation area. Just push it in.
The light was on and did go off...... means the switch should be wired correctly.
That whole front plate is removable for color changing. Possibly the pin is missing from the back of the button or the push switch is stuck.
I forget what the default time is set to. It can be changed to anything you want as it's fully programmable. The link is to the installation and programming of it. It can be a little intimidating.... sort of like programming an old VCR.
legrand/installation-instructions/single-pole-occupancy-sensor.ashx
