Junction box no source
Old 12-11-17, 08:35 PM
I have a wall box, which used to be for a light but the wires don't seem to be live even though every breaker is on.
they are oldish wires where the copper was a bit black so I cleaned then up with sandpaper but still no power.
All other receptacles or lights in the house have power so can't figure what's wrong.
My question is what do I do with these wires if I pull a new wire from the panel or another circuit? How can I terminate them since I am not sure if they're 100% dead or just a bad connection somewhere?
Old 12-11-17, 08:43 PM
XSleeper's Avatar
Received 298 Votes on 271 Posts
Assuming you can't trace or remove the wire, I would cap them and leave them in the box along with the new wire.
Old 12-13-17, 01:19 AM
What's the best way to trace it? Open up nearby lights and receptacles and locate the same wire type?
Old 12-13-17, 03:44 AM
pugsl's Avatar
Received 29 Votes on 27 Posts
Do you have any switches not working? You may have a switch loop.
Old 12-13-17, 05:56 PM
All switches and receptacles working.
need to trace it another way
Old 12-14-17, 05:55 PM
Will a wire tracer work through the wall?
Old 12-14-17, 08:54 PM
Received 36 Votes on 34 Posts
They will work to a certain extent, but will be useless unless the wire is completely disconnected from other wires. Also, if this wire runs parallel to other wires, you are more than likely to get false readings. It is hard to tell if the signal you are picking up is induced signal or the signal that is actually on the wire unless you put to probe right next to the wire. And this will be difficult without cutting the wall.
Unless you start opening every junction boxes and inspect connections, just capping the wires with wire nut is pretty much only thing you can do.
If your house has been remodeled, it could be cut and abandoned in the wall as well.
