GFCI Breaker and Outlet
Hello, looking for some help/clarification using terminology I don't have to look up or interpret ... if I have a GFCI breaker as the circuit breaker for a circuit (it's for the garage lights, outlets and GDO's) - I do not need to have any GFCI outlets, right? Or am I completely wrong? As I understand it (and I usually do not, as it seems, understand 'it' correctly), a GFCI outlet would be useless in a GFCI breaker-ed circuit, correct? Pushing the reset button on the outlet does nothing if the breaker is tripped, right? Or do some professionals view it as a benefit to have both?
And what about the 6 feet rule or whatever it is that states how far the protected outlet can be from wherever? That wording of the code always leaves me not understanding things.
Thanks for any answers you can give.
Anything connected to a GFI breaker is protected and does not need further GFI protection.
The 6' rule means any receptacle within 6' of a sink needs to be GFI protected.
The new code changes that. Any receptacle on a kitchen counter needs to be GFI protected regardless of the distance.
