125 amp sub panel.
Old 12-24-17, 05:39 PM
R
125 amp sub panel.
Hello friends looking to make sure I haven't missed anything. I plan to run a 2" pvc conduit with 1/0 conductors for the approximately 100-150ft to the sub panel. The conduit will be 24" deep and sch 40. I know that the neutral and ground are split at the sub panel and I will be connecting the existing ufer ground. This will be to power multiple equipment in my work shop.
Thanks,
Rich
Old 12-24-17, 05:53 PM
pcboss's Avatar
Received 84 Votes on 72 Posts
You will need 4 wires in your feeder as well as grounding and a means of disconnect at the outbuilding.
Old 12-24-17, 07:31 PM
R
Ok, perfect. I don't think I can run a 125 amp main in the sub panel with a 125 amp breaker in the main panel. What do you suggest?
Old 12-24-17, 08:16 PM
Received 1,043 Votes on 967 Posts
The breaker in the main panel protects the wiring and everything after it. The main breaker in the sub panel is only there as a main disconnect means. It can be the same size as the main panel breaker. Many times it's larger than the main panel breaker.
