Replacing normal switch with automation device - wiring question
Received 0 Votes
Hello,
I need guidance on my current wiring in the house and how I could decipher the right cables. Here is the current setup:
Switch 2 controls the room ceiling lights where these boxes are mounted.
What I cannot tell is which one is live source and which is feeding to the next one in chain. Is there a method to identify what is main source?
Desired setup:
Thank you in advance for your guidance.
Updated:
Attached pictures for the top switch B and drew it on a piece of paper for top switch B and top switch A.
- Currently there are 4 romex wires coming into a 2-gang box(Box A).
- There are 2 switches on the above 2-gang box.
- Right above the 2-gang box, there are 2 switches on it. (Box B)
- In Box A:
- 1 Romex wires has 4 cables in it - Red, Black, White and Bare
- remaining 3 wires have Black, White and Bare.
- Switch 1 -
- Top screw terminal has Red wire
- Bottom screw in terminal has black wire looped and then is connected to screw in terminal on the bottom in Switch 2.
- Bottom push in connector has a black wire coming in from 2nd Romex Cable.
- There is a pig tail Bare wire for the ground.
- Switch 2 -
- Top screw in terminal has black wire from 3rd romex cable.
- Bottom push in connector has black wire from the 4th romex cable.
Desired setup:
- Replace the switches with an automation device that requires Black, Neutral and GND as source and Output going to a light or an outlet.
- From the above wiring, is it write to make the following, Bundle all Black wires together and
- Automation Device A - Connect a black pig tail from above bundle to automation device A on the input side, Pig tail same for neutral to source wire(once I identify the correct romex 14-2 wire) and similar for ground. Connect Red wire to output(load) and white from the 4 wire Romex to the neutral on output side and bundle the bare wire with pigtail to ground.
- Automation Device B - Pigtail Black wire to the above bundle to input and take white wire from one live source and bundle it with a pig tail. Take the black wire from top screw in wire to output(load) and connect the neutral of that romex to output side and similarly ground.
Updated:
Welcome to the forums.
You have 2) two gang boxes (A & B) with switches...... one above the other.... for 4 switches total ?
Can you pull the devices out of the boxes (without disconnecting any wires) and post a few pictures for us. How-to-insert-pictures
Received 0 Votes
Hi Pete,
I updated my original posting with few pictures and drawing that I made from looking inside the outlet earlier.
Raj
Raj
I added two additional diagrams. We don't need to see the bare grounds. They are understood to be there and need to be connected.
I'm guessing in the bottom pic all whites are combined.
Received 0 Votes
I am planning to replace the bottom switch A and Switch B with an automation device. Automation device basically has on the input side, Black, White and Bare connections and output side has similar connection as well.
Received 0 Votes
I updated the bottom picture to show neutrals connected.
I see your link. What are you installing.... those p.c. boards inside the switch box ?
I have to tell you.... I'm not thrilled with that idea and even less with devices that are not UL listed.
