replacement power cord
Old 01-08-18, 12:27 PM
B
Question replacement power cord
I recently bought an old digital piano. The cord with it works, but is not original. The only specs I can locate in online manual just say that the power consumption is 50W (120V). The cord is stamped 7W-125V. Can it be safely used? Many thanks.
Old 01-08-18, 12:37 PM
L
Received 50 Votes on 46 Posts
Are you sure it is not 7A 125V?
7W is almost nothing and that would be a really thin wire. Even a lamp wire can handle more than that. Also, it is very rare to see a cord rated in wattage instead of amperage.
If it is 7A, you will be fine. That is about 840W.
Old 01-08-18, 12:39 PM
Received 2 Votes on 2 Posts
Are you sure it isn't labeled 7A-125V? 7W would not be enough to power much of anything.
Lambition got to it first
Old 01-08-18, 02:59 PM
B
Thank you. YOu're right. I misread it.
Old 01-08-18, 03:03 PM
B
Smile
Thank you. You're absolutely right; I misread it. I do appreciate the help.
