Mounting metal double gang electrical box to drywall
Old 01-10-18, 02:47 PM
D
Question Mounting metal double gang electrical box to drywall
I had a few situations where I had to install double receptacles (one GFCI one regular) in a 4 metal box on drywall where I had to install these on drywall surface using 1-1/4 drywall screws. 2 of these boxes are on ceiling and 1 is on wall.
The 2 on the ceiling are installed for one purpose only and that was to connect my jackshaft garage opener. They are on drywall ceiling by garage door. I have no conduit, the 12-2 NMB wire runs along side of the I beam connected to an existing junction box (all existing wiring are on ceiling and exposed without conduit, I only extended). I didnt want to install it on the thin side of the joist as its hard to find right middle of it and didnt want to risk of splitting it and having insecure connection.
The 1 other box is on a wall mounted in a similar fashion but this is on the garage/basement wall where there is no stud. Basically there is a double drywall on top of a 2x12 thats on its side.
I used 4 drywall screws on all these boxes. Is this okay?
Old 01-10-18, 04:49 PM
L
Received 44 Votes on 40 Posts
Having NMB wire exposed on the finished wall is violation of the code. This is because there is possibility of damage to the wire.
Cable on the ceiling is technically also not allowed since you have finished ceiling, but most inspector probably will say it is ok since they are unlikely to get damaged.
Just sleeve cable on the wall in a conduit or wiremold channel.
Old 01-10-18, 05:06 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
You can't mount boxes just to sheetrock/drywall. They need to be attached to framing members.
Old 01-10-18, 05:11 PM
pcboss's Avatar
Received 63 Votes on 55 Posts
The NEC specifically allows NM cables to be run on the surface of the wall of ceiling. It cannot be subject to damage, but that is entirely subjective to the inspector.
You need to use anchors in the drywall to hold the boxes.
Old 01-11-18, 03:06 AM
D
What kind of anchors?
I did not use those tiny metal drywall screws for this but the black coarse threaded heavy duty ones. When I pull the box, it feels very secure and I used 4 screws not 2.
Old 01-11-18, 04:13 AM
L
Any drywall anchor will do. Even coarse threaded drywall screw is not strong enough.
Old 01-11-18, 05:06 AM
Geochurchi's Avatar
Received 37 Votes on 35 Posts
How about using toggle bolts?
Geo
Old 01-11-18, 05:13 AM
D
The box is actually 4-5 from the joist. At this point its probably easier to move it as is and use 2 screws instead of 4 and attach it to the small end of the joist. Is this acceptable?
Old 01-11-18, 05:41 AM
L
Screwing to the joist is the best.
Toggle bolt will be little over kill.
Old 01-13-18, 06:11 AM
Tolyn Ironhand's Avatar
Received 132 Votes on 116 Posts
I use then metal version of these by the hundreds: http://www.powers.com/pdfs/plastic/02345.pdf. They are quite secure in drywall. There are similar versions sold at all home/hardware stores.
