Wiring Question For Hot, Neutral, Ground
Old 01-21-18, 06:03 PM
R
Hi Everyone,
Here is a pic of a light wire I have open:
https://imageshack.com/a/img923/4968/Z8yMFk.jpg
Unfortunately there are no colors (black, white, green) on the wires, just black electrical tape.
I have a voltmeter and I've identified the hot wire. Would anyone be able to help me on the steps I need to take in order to determine which wire is neutral and which wire is ground?
Thanks for all your help!
Old 01-21-18, 06:11 PM
pcboss's Avatar
Received 167 Upvotes on 146 Posts
The neutral should be identified, commonly by small ribs in the insulation.
Old 01-21-18, 06:13 PM
Received 3,485 Upvotes on 3,128 Posts
The fixture was removed from that cable and it appears there is heat shrink over the wires hiding their markings.
If you can't see the colors you will need to turn power off and use an ohmmeter to find out which is which. You can't use a voltmeter for ground and neutral because they ultimately connect to the same place in the electrical panel. You'd have to open the connection up at the canopy and check each wire one at a time.
Old 01-21-18, 06:47 PM
R
Ahhh Okay. I understand what to do now. Thanks Pete!
