Reload this Page >
Can you drill holes in electrical panel where there are no knockouts?
Old 01-23-18, 11:00 AM
I am still working on my panel upgrade. Yes, I know still! One problem I am having is the knockouts lining up between the meter main breaker panel and the distribution panel on the inside of the wall. I have the knockout in the prefect place in the distribution panel but there is not one on the outside meter panel. Can I just drill the hole in the panel or do I have to line up the knockouts?
skeeter
Old 01-23-18, 11:43 AM
core's Avatar
The NEC does not prohibit you from drilling holes in a panel as long as it is done in a workmanlike manner, and as long as you don't end up with openings when you are done. If your drill hole is going to overlap an existing knockout you may have issues that need addressing, but otherwise it's clean/easy.
Many commercial panels don't come with pre-punched KOs, so if you couldn't drill holes you could never wire anything. Also the manufacturers of knockout sets would be sad ponies.
Old 01-23-18, 11:53 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Chassi punches are also a good way.
Old 01-23-18, 01:17 PM
Good to know, thanks. It will make the job a lot easier.
skeeter
Old 01-23-18, 02:36 PM
Received 75 Votes on 70 Posts
I use a step drill for this job, makes a clean hole, and it can be used for other jobs.
Old 01-23-18, 05:27 PM
pcboss's Avatar
Received 84 Votes on 72 Posts
An offset nipple may help also.
Old 01-23-18, 06:44 PM
Step drills are great for smaller holes in sheet metal or plastic, but I will probably use a hole saw since I need a hole for 2-2.5 in. conduit. Offset nipple won't work in this situation since there is no hole in area I need one.
skeeter
Old 01-23-18, 06:53 PM
pcboss's Avatar
I thought maybe the hole just didn't line up.
Old 01-23-18, 07:32 PM
CasualJoe's Avatar
Received 85 Votes on 75 Posts
A hole saw will work, but the hole may be a little rough. This is what knockout punches are made for.
Old 01-23-18, 08:06 PM
Yeah, Hole saws are rough. I will have to deburr it. Knockout punches are great but a bit overpriced since I only have to do one hole. And I already have a hole saw.
skeeter
Old 01-24-18, 01:57 AM
core's Avatar
My set from Harbor Freight was $24 as I recall. Chinese made, but what isn't these days. The box is labeled "Knock Metal Set", and the other markings on the box leave a person wondering if they're getting a knockout punch set or a couple tickets to a pro wrestling match. But they work fine.
Old 01-24-18, 05:42 AM
ray2047's Avatar
It is best to start with a good quality never used hole saw. That cost could be over $15 (not including arbour) so cost of a cheap K/O punch could be similar.
