What size breaker?
Old 01-27-18, 12:16 PM
YesHaveSome's Avatar
What size breaker?
I am installing a mini split and nowhere in the manual does it state what size breaker is required. It's an 18,000 unit and based on other research I have done this usually requires a 30A breaker. Here is the nameplate on the unit:
Thanks
Old 01-27-18, 02:14 PM
Tolyn Ironhand's Avatar
Received 133 Votes on 117 Posts
Nameplate states max fuse or circuit breaker is 20 amp. You must follow the nameplate.
Old 01-27-18, 04:52 PM
pcboss's Avatar
Received 63 Votes on 55 Posts
You can wire that with#14 or larger wire.
Old 01-27-18, 04:54 PM
Received 747 Votes on 702 Posts
I would recommend using #12 especially if the run is 50' or better.
Old 01-27-18, 07:48 PM
L
Received 44 Votes on 40 Posts
mini splits usually are 20A with exception of larger units.
Whole house AC or heat pump usually are 30A, some smaller ones are 20A as well.
