Wire type from outside main disconnect to inside panel?
Old 02-01-18, 12:44 PM
What are acceptable wire types to go from my 200amp main meter disconnect to just on the other side of the wall to my 200amp main panel? SEU, SER, THHN, XHHN. Found a good deal on 2/0 copper THHN wire. Can I use that?
skeeter
Old 02-01-18, 12:58 PM
I
Received 42 Votes on 40 Posts
If it's through a conduit nipple, the THHN would be a good choice.
Old 02-01-18, 01:23 PM
Well it is goes out top of the meter box into an LB Body thru the wall into the back of the panel. Meter will be a little lower than the panel. So that would be close enough correct. I was planning on two 2/0 copper hot leads, one 2/0 neutral lead and then a #4 bare ground copper. The THHN is about $1.75 ft so that would be great. Does that sound like an adequate plan?
skeeter
Old 02-01-18, 07:15 PM
Received 747 Votes on 702 Posts
That will work. 2/0 is allowed for a 200A service in a residential application.
Good price on that wire.
Old 02-02-18, 07:28 AM
P
Received 45 Votes on 38 Posts
My understanding is 3 wire service sizing is from the meter base to the first OCPD disconnect. From the first OCPD disconnect to the breaker panel is sized based on table 31015(b)(6) which calls for 3/0 Cu for 200A.
#6 Cu can be used for the EGC for 200A.
Old 02-02-18, 06:28 PM
CasualJoe's Avatar
Received 62 Votes on 53 Posts
I believe there is an exception that the feeder between the disconnect and the subpanel does not have to be larger than the service entrance wiring to the first disconnect. Meaning that if 2/0 copper is used between the meter and the disconnect then 2/0 copper can also be used between the disconnect and the subpanel.
Old 02-03-18, 06:18 AM
P
Yep.. you are correct for when the feeder is supplying the entire supply to a dwelling. 2014 NEC 319.15(7)(3). I had my feeder sizing confused. It is from the main service panel to a subpanel that a branch feeder is sized from 310.15(B)(16).
