Transition from Conduit Body to Disconnect Box
Old 02-02-18, 01:34 PM
W
Hi,
I came through my outer house wall with EMT conduit that I have a raintight compression connector on the conduit body. I need to get the conduit body to a AC Disconnect box. Do I need to run a raintight compression connector on the conduit body, and then a piece of EMT and then another raintight compression connector on the bottom of the disconnect box?
I assume there is a simpler way that will look a lot better too.
Thanks for any help - Wil
Old 02-02-18, 01:45 PM
Geochurchi's Avatar
Received 96 Votes on 89 Posts
Not quite sure what you are trying to do but the outside must have a compression fitting on it,on the inside connection to the disconnect can be a standard set screw connector.
Post a pic so we can see what you hav there.
Geo
Old 02-02-18, 02:05 PM
W
Here is what I am trying to describe above. Has to be a better way to do this.
Old 02-02-18, 09:16 PM
pcboss's Avatar
Received 114 Votes on 99 Posts
