Best position for high amp breakers?
Old 02-07-18, 03:08 PM
Just for giggles i was wondering about some peoples opinion on this. Where do you try to position high amperage breakers (e.i. 30-100amp 240v) on the main panels bus bars. Near the main breaker, opposite end, middle, spread out? Why?
skeeter
Old 02-07-18, 03:32 PM
L
Received 50 Votes on 46 Posts
Doesn't matter where you have it.
Old 02-07-18, 04:22 PM
A
Received 36 Votes on 32 Posts
Coke or Pepsi?
Limitations I can think of off hand:
Some panels had warning about max amps on a stab when using tandems.
With old split-bus panels 240v loads would go on the top section as the lighting section might only be fed with 60amp.
PV breaker may need to be at opposite end of main.
Old 02-07-18, 05:28 PM
Received 940 Votes on 877 Posts
My personal preference is at the top near the main breaker.
Keeps the large current draw off the entire bus.
