Install Mini Split AC Unit
Old 02-24-18, 11:06 AM
B
In the planning stages of installing a 18k btu mini split ac system. It requires 230 volts and I have two open
slots on my electric panel, so I should be good to install a 30 amp breaker. What size wire should I run to
the disconnect box on the outside of the house? Thanks in advance.
Old 02-24-18, 11:45 AM
Geochurchi's Avatar
Received 91 Votes on 86 Posts
Follow the mfg. specís. normally that will be in the owners manual or on the name plate.
Geo
Old 02-24-18, 12:03 PM
Received 1,476 Votes on 1,364 Posts
The correct tag to follow is the one on the unit. It will state minimum ampacity required and maximum overcurrent protection. You can post a picture of the tag if you have the unit.
How-to-insert-pictures
