Installing a sub panel?
Old 03-01-18, 07:45 PM
T
I want to run a second breaker box in my house. I don't want to run 5/6 wires 60' so a second box seems like the easiest way to go. I will be running 5/6 circuits plus a circuit running to my garage. I have a spare 100 Amp box and breakers so that will not cost me anything. Question is, what size wire do I run from box to box? And what size underground cable to the garage (about 15') Garage will only have a few outlets, few lights and garage door openers. Maybe a small 120 air compressor. Is there something that has to be wired different on a sub panel, something about the neutral and ground can't go on the same bar? Thanks
Old 03-01-18, 11:35 PM
pcboss's Avatar
Received 109 Votes on 95 Posts
The panel feeder size will be determined by a demand load calculation m based off of the loads served.
Old 03-02-18, 07:02 AM
P
Received 138 Votes on 111 Posts
Neutral is isolated in any panel after the first main disconnect which is the main service panel. Most panels when used as subpanels require the purchase of a ground bar kit and the existing bar in the panel will be used only for the neutrals and the bonding screw/strap from that bar to the panel needs to be removed.
Old 03-02-18, 10:03 AM
A
Received 49 Votes on 44 Posts
There are some good diagrams on the site - https://www.doityourself.com/forum/e...-diagrams.html
Old 03-03-18, 07:53 AM
T
Thanks
Thank you for the replies. Those diagrams are very helpful.
