Checking transformer voltage behind my door bell
Old 03-04-18, 11:34 AM
I was given a fluke meter 77 lV multimeter and I want to check the voltage output from the transformer behind my front door bell. I have never used a multimeter before. Which plugs do I choose for the leads connection and also which setting I choose with the dial? Again I am trying to find out the output voltage behind my front door bell button... Need Help Please... Is there a YouTube video showing me exactly what to do or can someone please give specific instructions to help me.
Thanks In Advanced. SaltheHippy.
Old 03-04-18, 11:59 AM
d_s_k's Avatar
Received 19 Upvotes on 17 Posts
Just turn the switch one step to V AC (AC=~) plug the 2 cables in to the jack on the right side Usually we put the black on COM.
Picture: http://lgstatic.transcat.com/media/e...-77-iv-cc2.jpg
That instrument is auto range so you may measure the mains or the output with the same setting. Do not touch any live wires! Usually the output of a transformer like that is about 8V If it have some markings of voltage, it will usually be some higher reading until someone presses the ring button.
dsk
Old 03-04-18, 12:22 PM
Received 3,485 Upvotes on 3,128 Posts
Welcome to the forums.
If you measure the AC voltage at the doorbell button.... you should see 14-20v AC.
The transformer base voltage is usually 16v.
