Making a 220 Extension Cord
Old 03-12-18, 11:37 AM
Hello,
I am currently in need of a 220 extension cord for my Jointer. My Jointer is a Grizzly G1018 -220v- 1.5HP - 9amp Jointer.
I have read the instruction manual it gives recommended wire gauges for certain lengths of extension cords.
I am in need of a 50' extension cord. My manual states that for 11-12 amps I can use 16ga wire and for 13-16 amps i can use 12ga wire.
Does this seem correct? At 220v my jointer requires 9 amps. Does this mean I can use 16ga wire for my extension cord? that just seems like too light of a guage for this.
here is a link to the manual for my jointer.
https://cdn0.grizzly.com/manuals/g0500_m.pdf
Any help on this would be appreciated.
Old 03-12-18, 11:43 AM
I would size the wire based on the circuit. If it's a 15 amp circuit, I would use at least 14 ga wire. If it's a 20 amp circuit, I would use at least 12 ga wire.
No chance of skipping the cord entirely by adding a new receptacle closer to the tool?
Old 03-12-18, 11:48 AM
Unfortunately no, the only thing I could do other than the Extension Cord; is make the power cord for the Jointer longer.
Old 03-12-18, 11:59 AM
Using to small a gauge wire will cause the motor to overheat.
Making the cord longer will save you the cost of another connector.
Old 03-12-18, 12:21 PM
Don't even mess around. For a 50' extension cord.... use #12 wiring.
Old 03-12-18, 12:32 PM
@Joe - That sounds like the way to go. If I buy a 12/3 SJTW Heavy Duty Extension Cord with standard 110 plugs, can replace the connectors and use it for the longer power cord?
Old 03-12-18, 01:00 PM
Joe is recommending adding a 50' power cord to the tool. Not using an extension.
There is no problem cutting off the 120v caps and installing 240v ones in their place.
Old 03-12-18, 01:03 PM
Perfect, thank you guys very much.
Old 03-12-18, 01:35 PM
So for instance,
I could buy this extension cord
https://www.amazon.com/US-Wire-74050...sion+cord+sjtw
and replace the caps with the correct 220 ones for my jointer?
thank you
Old 03-12-18, 01:56 PM
I would not use a SJTW code because of the stiffness. I would make one up using SJOOW cord, way more flexible and easier to coil.
