New 12v LED Fixture with Existing Panelized Lighting
Received 0 Votes
Hello, I will be replacing an existing ceiling fixture with a new one but my project has a number of complications.
Old Fixture:
New Fixture:
Power Source:
Questions
When I tried to clarify with the manufacturer, I received the following:
But this doesn't seem to clear up my confusion. 14-2 is already run to the existing transformer and then more 14-2 from the transformer to the existing fixture. Are they saying I need 2 more conductors in addition to the 2 in the ROMEX?
Thanks, Jeremy
Old Fixture:
- 12-volt track-style fixture
- 12-volt WAC Lighting remote transformer SRT-300M-12V
New Fixture:
- 24-volt Nemo Ellisse Double LED Suspension Light
- Uses integrated transformer LPF-90D-24
- Apparently, for dimming, the fixture/transformer requires an additional 2 wires be run from the dimmer according to some things I've read
Power Source:
- Lutron Homeworks Interactive (circa 2004) Panelized lighting RPM/Dimmer
Questions
- Confirming that I will be bypassing/removing the existing WAC Lighting transformer...
- Will this fixture dim without running the extra 2 wires?
- Will the new fixture work/dim with the existing feed from the panelized lighting?
- If wires must be run for dimming, then where would they run from?
ELLISSE PENDANT DOUBLE is
- 24V
- Dimmable 1-10V (you need 2 wires)
- The driver inside the canopy is already dimmable: you need only a 1-10V controller
Thanks, Jeremy
You need two additional wires from the fixture to the dimmer location. You can just purchase a 100k ohm variable resistor or a 1-10v lighting controller.
This is one such dimmer.... there are many. This dimmer would be in addition to the on/off switch.
ledsupply/dimming-control-0-10v-low-voltage-wall-mount-control
