100A subpanel for detached garage
I need to run a 100A feeder to a new construction detached garage.
The main house has 200A main panel, and a 100A subpanel. Both panels are full.
code is NEC 2008 but requires conduit.
Please sanity check my plan....
1) Install 3rd panel in main house to supply the garage.
- feed 3rd panel via 100A breaker in main panel.
- move 2 or 3 circuits to the new 3rd panel to make room for the 100A breaker
- extend those circuits with wire nuts and wire extensions to reach the new 3rd panel
- Install new 100A breaker at the bottom of the main panel, on the phase opposite the 1st 100A subpanel breaker (did that make sense?)
2) Run 2-2-2-4 MHF (mobile home feeder) to a subpanel in the new garage.
- Run the MHF in 2" conduit (yikes) to the house exterior under the back deck
- switch to 2" PVC on the outside
- run above ground under deck a length of 50ft
- then burry 18" and run underground 30ft to the garage service entry.
- bring the 2" PVC up and punch it through the building.
- enter the Garage subpanel through the bottom.
a few questions:
- extensions/wire nuts are allowed inside panel boxes?
- can the 100A breaker be at the bottom? I've only seen them at the top.
- what wire to supply the 3rd subpanel from the main panel? the same 2-2-24 MHF? the existing subpanel has a 3 wire setup, but that may no longer be code?
- does under a deck count as "under a building" per NEC code? NEC 2008 allows exterior above ground runs in conduit under a building.
here's pics of the existing main panel & sub panel....
a few questions:
#2 MHF is only rated at 90A when used as a branch feeder. For a 100A sub feeder you need to use #1 Al or #3 Cu. You also need to verify that your panel allows branch circuit breakers as large as 100A.
hey are you the same pattenp from garage journal?
so the mhf I was looking at is rated USE2/RHH/RHW-2. if i'm reading 310.15 correctly it states #2 AL is good for 100A serive or feeder? 310.16 describes insulated conductors in conduit and also states 100A for USE2/RHH/RHW-2
what am I missing?
what am I missing?
what am I missing?
what am I missing?
ok I think I get it.
So the existing sub panel is fed by (3) #1 Cu wires. but no 4th wire. Is that because the conduit handles the ground? I'm assuming I'll have to run a ground wire to the detached garage, though? where would I connect it in the house? tie it to the panel? if you notice in the pics there's no ground terminals in either of my panels.
