Reload this Page >
Surface mount exterior (weatherproof) junction box for exterior light?
Old 03-20-18, 07:54 PM
L
Received 177 Upvotes on 152 Posts
I need to install a exterior light on a red brick wall.
Since it is a brick wall, surface mount will be the easiest way to go and only suitable junction box I find is round weatherproof junction box.
The issue with this junction box is most exterior lights have a larger base plate than this junction box because they are meant to seat against the wall.
Any suggestions?
Old 03-21-18, 05:40 AM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
I wonder how a faceplate from one of the Arlington siding blocks would seal against the WP box. It would certainly dress up the front and give a better mounting surface for the light.
Old 03-21-18, 06:05 AM
L
I don't link the siding block you mentioned will work over the weatherproof box, but instead I found this.
https://www.amazon.com/Arlington-816...rds=siding+box
Looks like I could use this box instead of weatherproof box.
Don't like how shallow the box is, but should be enough for just a light.
Old 03-21-18, 11:23 AM
Received 3,422 Upvotes on 3,068 Posts
I've actually chopped the brick out to install a cut-in gem box. Makes for the neatest looking job but is a little involved.
That box you linked to should work fine. It is shallow but between that and the canopy of the fixture.... you shouldn't have any problems with room for the splices
