Wiring outlet to 3-way switch
I have a 3 way switch set up that I want to add an outlet to. I have access to the switch that has only 3 wires and a ground. It has a black attached to Common then a red and white attached to the travelers. I want to add an outlet to this that is only powered on when the circuit is powered. I believe I would attach the black for the outlet to the black on the switch, but how do I get the other two on there?
You need to parallel the outlet (2 wires and ground) from the load (light) controlled by the 3-way switches.
Received 273 Upvotes
Why did he say this if wanting a constant powered outlet? I take that as meaning a switched outlet.
