Is this OK for safety?
Old 03-23-18, 04:22 PM
R
In the attic I have a splice going to a light I no longer use so I disconnected it. I capped and taped the wires. Is this enough for safety?
Thanks
Old 03-23-18, 04:50 PM
Received 3,181 Likes on 2,856 Posts
No. Splices must be contained within a junction box.
A small handy box with blank and NM-b romex connector is all you need.
Old 03-23-18, 06:20 PM
R
Will this do, it's one of those blue boxes with a cover.
Old 03-23-18, 06:59 PM
Th at will do to. It needs to be fastened to a joist and the cable needs to be stapled within 6" of the box.
Old 03-23-18, 08:58 PM
R
Great, thanks a lot for the help!
Old 03-23-18, 09:19 PM
ray2047's Avatar
Note wire nuts do not need to be taped. There is no reason to cap the ground wire with a wire nut since the whole wire is bare.
Old 03-24-18, 06:22 AM
Tolyn Ironhand's Avatar
I like to cap a bare ground wire (or any ground for that matter) just to make sure the end of the wire does not get pushed into another wire nut by accident.
