Adding 220 plugs
Received 0 Votes
Adding 220 plugs
I hope this forum is also for us non electricians trying to do it ourselves.
I have a house built in 1957 that I just had my electrical panel upgraded. I want to add TWO Amana AC/heater units that call for 230V / 20amp plugs. I want to run the lines outside the house from the box either along the wall or buried. I prefer to use electrical PVC as it's easier to work with. Here's my questions;
1. Do I need two separate breakers or can I use one with higher amperage?
2. If I can use a single breaker what wire should I use? Should it be a bigger gauge between the electrical box and the junction/split to the two units?
3. How deep do I need to bury the wire in California?
Thank you for your time!
Glen
Glen
Two 240 circuits will leave you one spare space there.
Buried PVC needs to be 18" deep. Then neatest way to do the job is to bury the PVC right next to the foundation.
Received 0 Votes
I also noticed that the electrician used a dedicated 15 amp breaker just for my doorbell. Could I combine this wire with another breaker or must I waste one just for a doorbell? I'm trying to leave two open for later use.
