Air watts
Air watts are calculated using the formula, (Air flow (in CFM) x vacuum (in inches of water lift)) / 8.5 = Air Watts.
Air watts is a fairly useless rating measuring wattage out of a vacuum. The vacuum you are looking at should spec out the amperage required.
