Suddenly no power at outlet
Old 03-29-18, 05:54 PM
B
Question Suddenly no power at outlet
I'm hoping someone can help me - my dishwasher suddenly stopped powering on. Was working fine yesterday.
Here's what I know so far:
I have tested the voltage across the circuit breaker. 120V - I think this means the breaker is not the problem.
I have tested the three wires at the dishwasher. Here's what I get:
  • Black wire to ground: 120V
  • Black wire to white wire: 1V
  • White wire to ground: 0V
Dishwasher is wired directly (not plugged into an outlet) and is the only thing on the circuit - no other outlets.
Any assistance is greatly appreciated!
Old 03-29-18, 05:58 PM
Received 1,531 Votes on 1,414 Posts
Welcome to the forums.
You should get 120vac from black to ground and 120vac from black to white.
You have an open neutral somewhere.
It's either loose at the panel or there is a splice/junction point in the line.
Old 03-29-18, 06:00 PM
Received 104 Votes on 91 Posts
Black to white should have been about 120 volts.
Sounds like a loose neutral wire some place to me.
Old 03-30-18, 09:49 AM
B
Thanks
Thank you both for your insight.
I'll turn off the main breaker and see if I can locate a loose neutral. If not, worst case I guess, I can probably use the wire that's there to pull a new one - it's not a long run.
Thanks.
CC
