Wires without a bushing in the panel on inspection report... HELP!?
Received 0 Votes
Hello,
I am selling my house and was told in the inspection report that some of the wires penetrating the panel are not protected with a wire bushing. Does anyone have a video or pictures that shows how to take care of this? I am having trouble finding examples online. How do I know what types of bushings I need? I'm a beginner at this sort of thing if you cant tell already.
Thanks!
Thanks!
If you have the cover off the panel..... shoot and post a few pics for us.
How-insert-pictures
Depending on type of cable .... NM (non metallic) for example... they have split grommets you can install from inside the panel.
How-insert-pictures
I added a second enlarged picture. The split grommet I illustrated in my previous post will work. It may be tough to get in there as that doesn't look like a true 1/2" KO opening.
Worse comes to worst.... you could use a rubber grommet or a hard plastic bushing. Cut one side open. Takes a little doing to get in but will work there.
Home improvement stores will carry all of them in the electrical aisle.
If they are the same size. Try squatting down and post a picture of just the top half of the panel.
While working in the panel, I would suggest turning off the main breaker (at the bottom). It will de-energize the bus bars up the middle - but the incoming wires will still be live.
You can definitely do what you need to do carefully - but be careful of screwdrivers and such while you're working in the panel.
