Reload this Page >
Ariel BT-062 Whirlpool Tub 220v electric connection issues
Old 04-04-18, 12:27 PM
B
Hi All,
I bought a whirlpool tub Ariel BT-062. It has an air pump only but it is advised to connect with a 220v 60hz line. The connection cable is very thin like 16 gage. It has only White, Black and Gree(=Ground Cable) cables. Now the confusion is whether we have to use a "12-3" cable to bring 2x120v line to it. If yes, then how to connect it. It is also recommended to install a 30amp GFCI breaker. if anybody has a previous experience with any Ariel bathtub installation with similar issues then please share your experiences.
Old 04-04-18, 02:34 PM
pcboss's Avatar
Received 84 Votes on 72 Posts
Is this tub built and meant to be used in the US? I don't see a UL listing mark.
In the US the voltage is 120 and 240.
Old 04-04-18, 02:41 PM
B
I am not sure. It is sold here in USA. Now I am stuck.
Old 04-04-18, 06:35 PM
Received 1,043 Votes on 967 Posts
It's sold at Home Depot. home depot/Ariel-Whirlpool-Tub-in-White-BT-062
The installation instructions are useless as they are poorly translated from a different language.
You'd only need 14-2 w/ground to that unit on a 2P15A circuit breaker. It MUST be GFI protected. I see the cord in your picture. What is on the other end of it ? A switch is discussed in the installation. Is there any switch on the unit ?
Old 04-04-18, 10:32 PM
B
Thanks, PJMAX. The other end of the cable is connected to the motor itself. The confusion is, it said to supply 220v but how can we provide 220v/240v to these non-standard 16 gauge cable? We will try out your suggestions. Please provide your suggestions for this installation. There is a switch for on/off but that is located in the tub. It is not separate.
Old 04-04-18, 10:52 PM
B
how about this circuit breaker?
https://www.homedepot.com/p/Q-Line-15-Amp-Single-Pole-Ground-Fault-Circuit-Breaker-THQL1115GFP/100174142
Do we have to supply 120v or 240v to this Air pump connectors?
Old 04-05-18, 05:21 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
My guesses: It is 240 volts based on the nameplate. No 120 needed since the cord is only 2 conductors. It is probably less than 15 amps based on the nameplate therefore as Pete said use a 15 amp double pole breaker.
If you can not call the manufacturer and get a clear answer as to how to install it I'd put a 6-15 (240) plug* on the cord and install a 6-15 plug. Use a 15 amp 240 breaker and 14-2 NM-b to the receptacle.
Pictures of the tub on HD seems to show an air switch on the tub so by switch they may mean a disconnect. A plug and receptacle qualifies as a disconnect. You might also install a two pole switch ahead of the receptacle.
The breaker you posted is single pole. You need a double pole intended for your breaker box. What make of breaker box do you have?
*I suggest a plug both because a cord is not rated for hard wiring and you may need a disconnect to meet code.
Old 04-05-18, 05:36 AM
pcboss's Avatar
Unless it is the language isssue, I wonder why they are calling for a 30 amp circuit for a 4 amp load.
