How bad did I screw up?
Received 0 Votes
I was changing a GFI outlet in my basement. I wasn't sure exactly which breaker this circuit was on, sooooo I attempted to do the switch out with the electricity still on. As you can probably predict, I was careless & had a small but scary electrical event (pop!!!) triggering the breaker. Well now I felt much more confident in simply switching out the outlet much more safely. Once done, i flipped the breaker back on but now all of the outlets on the circuit are dead.
How much damage did I actually do? And how do I go about correcting this?
Thanks in advance
Thanks in advance
There should usually be only one GFCI on the first receptacle or at the breaker. Common practice is to use non GFC fed from the load side of the first receptacles on all but the first. If you have more than one check that none are tripped.
If that doesn't resolve it you need to open the receptacles and look for any loose wires. Any backstabs* need to be moved to the screws.
*GFCI connections are not backstabs so they are not moved to the screws.
Received 0 Votes
After isolating all of the individual components in the circuit, it appears the only problem is the new GFI outlet itself. When I take it out of the circuit everything downstream works just fine.
