Extending a 220v circuit
Old 04-09-18, 06:00 PM
So when I re wired my detached garage with a sub panel I installed a 30 amp breaker with 10 gauge wire for 220v outlet. At the time I was not sure where my 220v outlet was gonna go so I only ran about 6 feet of 10 gauge black, red, and green stranded wire. The conduit runs up behind my wall and just sits on the ceiling of my laundry ceiling in a metal kunctioj box.
i​​​​​ now want to add my outlet but need to run about 10 more feet of wire. Can I run 10 gauge romex from the metal junction box and down inside a wall where I plan to put my 220v outlet for my welder? Meaning I will be attaching solid 10awg to stranded 10awg.
Old 04-09-18, 06:12 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Nominal voltages are 120v and 240 volts. You only need 2-conductor wire for 240 volts. Cap the neutral on the initial run and use 10-2 for the new run. Yes you can splice stranded to solid.
Old 04-09-18, 06:36 PM
My existing run doesn't have a neutral. It has a red and a black (hot) and a green for ground. Would it be okay to still use 10/2 wire which has a black, white, and aa bare ground?
​​​​​​Also, will a wire nut be sufficient to make a good connection capable of up to 30 amps?
Thanks
Old 04-09-18, 09:10 PM
ray2047's Avatar
OOpsI was thinking cable not conduit. What you have is fine. If you run cable in the wall you would use 10-2 NMB with the white remarked black, red or any color but gray or green.
Wire nuts are good for way more than 30 amps.
