Disconnect upgrade
Received 0 Votes
Disconnect upgrade
Redid the disconnect .
Is a bit tight though.Am going to upgrade the old wire to lower breaker an top breaker later.
Does everything look good?
That's a strange panel. Usually the breakers are the other direction..... and usually the breakers are centered in the enclosure.
Is there an inside cover for those breakers ?
I will assume this is a 240 volt only sub panel.
I cant tell on the wire sizes but 40 amps should be minimum of #8 and 30 amps should be minimum of #10 wire.
White wires should be marked as an ungrounded using tape or marker.
Anti oxidation paste should be put on any aluminum connections.
https://www.homedepot.com/p/Siemens-...-100143883-_-N
This appears to be what the op has installed. 4 space main lug instead of a disconnect.
Looks good to me.
Looks good to me.
Received 0 Votes
Yea it goes to heat pump .Its Siemans
I did use the noalox on all main incomming wire .
Running new #6 soon to 40 an new #8 i already have to the 30..
It has the front cover just not on it in that pic
Received 0 Votes
Already connected on otherside just havent run to box yet.
Ty
