Reload this Page >
Underground wiring from 9yr old house to garage not up to code?
Old 04-17-18, 11:23 PM
I was looking into installing a 14-30 outlet in my garage for future EV charging. Currently my panel has a 2 pole 40A breaker servicing the garage (door opener, lights, 2 outlets). I had a look at the wiring leaving the house and entering the garage and it seems to be 14/3 gauge. From all the wiring charts I've seen online, they all say a 40A circuit should use 8/3 gauge wiring. I'm afraid that if I install a 14-30 outlet it may cause a fire. Did the builder not follow code?
Old 04-18-18, 05:11 AM
Geochurchi's Avatar
Received 18 Votes on 18 Posts
Certainly not code if you have a 40 amp breaker feeding #14 ,should only be 15 amp.
Geo
Old 04-18-18, 04:15 PM
Tolyn Ironhand's Avatar
Received 59 Votes on 52 Posts
The breaker you need to look at is where the feeder originates, which is likely in your main house panel. If the 40 amp breaker is located in the garage it is likely only a disconnect.
If you are confused you can post some pictures. (instructions are in the stickies)
https://www.doityourself.com/forum/e...-pictures.html
