wiring from a spring timer to a digital timer
Old 04-19-18, 09:08 PM
Hello, We have a timer switch for our attic fan. its on a 12-hour spring wound timer,
It has 2 hots ONLY.. Yes both are hot. no ground. no other wires.
I would like to change the wind up timer into a 8 hour digital countdown timer which has 4 wires.
I don't wish to have to cut into the Sheetrock, and attic fishing is also off the table.
I am hoping for an easy work around. green or ground I can just ground from the metal box.
Old 04-19-18, 09:10 PM
Received 519 Votes on 489 Posts
Welcome to the forums.
It can't have two hot wires. It could have two black wires.
Do you have two black wires on the timer and two white wires connected together back in the box ?
Old 04-19-18, 09:18 PM
. TY PJMax, there are only two black wires. My husband said they where both hot.
Old 04-19-18, 09:28 PM
I'm guessing he used a non contact tester ?
Electrical cables come with at least a black and white wire.
If you only have two black wires in that timer box.... then that means you have a conduit system in the house. Is that correct ?
Old 04-19-18, 09:32 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
If he used a non contact tester there is a good chance he is wrong.. A non contact tester is too inaccurate for real testing. He needs to use a multimeter (preferably analog). However if no ground or neutral at the switch really no way to make a meaningful voltage test.
Dang, PJ types faster.
Old 04-20-18, 05:51 AM
Tolyn Ironhand's Avatar
Received 74 Votes on 66 Posts
You may be able to install the wires you need if the wiring method is conduit. If both wires are black it likely is conduit. You will need to access where the fan junction box is.
Is there a reason you can not fish the walls?
