Reload this Page >
Can I use X1 and X2, running back to the same neutral bus?
Old 04-20-18, 06:29 AM
Hi,
I have a general question to understand a 240V circuit. I have a control panel with components that run at 240V and components that run at 120V. I power 120V components by connecting to the X1 and neutral terminal strip.
I know I can either use X1 or X2, together with neutral to power the 120V components. I’m not sure if I can do both within the same panel. Can I use X1 and X2, running back to the same neutral bus within the same control panel?
That will cause a short, right?
Maybe a stupid question…
Thanks!
Old 04-20-18, 07:21 AM
I
Received 44 Votes on 42 Posts
You can use both hot legs to neutral for powering 120V components. In the code it's called a multiwire or shared neutral circuit.
X1 ---- 120V ---- N ---- 120V ---- X2
The two main concerns in this case are that both legs of the circuit are simultaneously disconnected by the breaker or disco switch you so you can properly lock this panel out. And that each component have the right overcurrent protection -- the 120V components might need a separate fuse or breaker if the incoming 240V source is breakered too high.
Old 04-20-18, 07:34 AM
Thanks Ben. I know I have to protect the wires.
So, below will work?
Old 04-20-18, 07:36 AM
I
Yes that plan is good................
Old 04-20-18, 08:08 AM
Thanks for the help Ben.
This would work, right?
Old 04-20-18, 09:33 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Correct except for labeling. X1 and X2 at the heater is 240 volts. I'd put 15 amp inline fuses on the lights since your breaker is 30 amps.
Old 04-20-18, 11:21 AM
Perfect! Thank you very much Ray!
